Hi all,
I have a GARMIN GTX 335 with integrated GPS and GARMIN GAE12. The GPS and the GAE12 are working fine. The transponder is not working at all.
Directly after power-on I got the following message: "TRANSPONDER FAILED"
Pressing the buttons "ALT", "SBY", "VFR" has no effect.
Under "MESSAGES" there is only the following entry:
"1090ES ADS-B OUT FAILED"
An aviation engineer successfully checked the antenna (RAMI AV-74) and the antenna cable. He also reviewed the wiring. Unfortunately he did not found an error.
The GTX335 device was also tested outside the airplane with another antenna and another power source. The failure still exists.
hardware p/n and versions:
XPDR: p/n 006-B1607-09, version 2.12
GPS: p/n 006-B1827-00, version 6.0
ALT: p/n 3T6005914
pin assignment (P3251):
configuration:
Has anyone an idea?
Thank you!
Pascal
ALT: p/n 3T6005914
Code:
PIN 21: VAC 14V
PIN 42: VAC 14V
PIN 20: AIRCRAFT GROUND
PIN 41: AIRCRAFT GROUND
PIN 9: RS232-OUT (Moving-Map: SKYMAP)
PIN 31: RS232-IN (Moving-Map: SKYMAP)
PIN 52: RS232-GND (Moving-Map: SKYMAP)
PIN 44: USB-VBUS
PIN 2: USB-DATA-Hi
PIN 24: USB-DATA-LO
PIN 45: USB-GND
PIN 43: CONFIG-POWER (GAE12)
PIN 23: CONFIG-GND (GAE12)
PIN 22: CONFIG-DATA (GAE12)
PIN 1: CONFIG-CLOCK (GAE12)
PIN 25: OAT-IN (DAVTRON C307PS)
PIN 3: OAT-OUT (DAVTRON C307PS)
configuration:
Code:
INTF
RS232
CH1
INPUT: XPDR FMT 1
OUTPUT: XPDR FMT 1
CH2
INPUT: XPDR FMT 1
OUTPUT: XPDR FMT 1
CH3
INPUT: OFF
INPUT: OFF
A429 IN
CH1
FORMAT: OFF
SPEED: N/A
CH2
FORMAT: OFF
SPEED: N/A
A429 OUTPUT: OFF
DESTRETE IN
PIN NONE
FUNC AUD MUTE
AUD
AUDIO OUTPUT: XPDR
VOICE: MALE
VOLUME: 50
TEST AUDIO: NONE
ALTITUDE ALERT: OFF
TIMER EXPIRED ALRT: OFF
TRAFFIC ALERT: MESSAGE
ADSB
ACFT CATGRY: LIGHT
ACFT MAX A/S: <= 150 kt
ACFT STALL METHOD: DEFAULT
ACFT STALL SPEED: N/A
AIRCRAFT LENGTH <= 15mt
AIRCRAFT WIDTH: <= 23mt
1090ES OUT CONTROL: DISABLED
UAT OUT RMT CONTROL; N/A
1090ES IN CAPABLE: NO
UAT In CAPABLE: NO
AIRCRAFT TAIL NUMBER
ADDRESS: HEX / 3D42EA
ALLOW PILOT TO EDIT FLT ID: NO
DEEFAULT FLT ID: ENTRY DEXPA
FLT ID PREFIX: NONE N/A
SENSOR
UAT SENSOR INSTALLED: YES
ALTITUDE SOURCE 1: ALT ENC
ALTITUDE SOURCE 2: NONE
GPS 1 SRC: INTRNL
LAT OFST: UNK
INTGRTY: AUTO
LON OFST: UNK
GPS 2 SRC: NONE
LAT OFST: N/A
INTGRTY: N/A
LON OFST: N/A
INTERNAL ALT ENCODER INSTALLED
INSTALLED: YES
CEILING: 13500
TEST POINTS: 3
INTERNAL ALT ENCODER ADJUSTMENT
TEST ALT: NONE
CORRECTION: N/A
MEASURED: ---- ft
DISP
DISPLAY BACKLIGHT: PHOTOCELL
MINIMUM LEVEL: 0
KEYPAD BACKLIGHT: PHOTOCELL
MINIMUM LEVEL: 0
PHOTOCELL TRANSITION: 25
SLOPE: 50
OFFSET: 50
LIGHTING BUS INPUT VLTG: 14 VDC
SLOPE: 50
OFFSET: 50
DEFAULT BACKLIGHT OFFSET: 0
DEFAULT CONTRAST OFFSET: 0
UNIT
ALTITUDE UNITS: FEET
TEMPERATURE UNITS: CELCIUS
INSTALLED ID: 1
VFR ID: 7000
ALTITUDE ALERT DEVIATION: 250 ft
RESTORE PAGES ON POWER-UP: YES
FLASH MESSAGE INDICATOR: YES
EHS: DISABLED
DIAG
DISCRETE INPUT STATE
TIS-A: NC
STANDBY: NC
SQUAT: NC
ALT DATA: NC
GPS
SRC 1: LAT 54,43?
SRC 2: OFF
Has anyone an idea?
Thank you!
Pascal
