What input serial port on the GTX-327 do you have the AFS altitude out connected?
There are two input serial ports on the GTX-327. The one on pin 2 is for aviation data to auto transition between STBY & ALT, while the one on pin 19 is for Altitude input. Whichever port on the AFS that you have configured for ICARUS out should be connected to GTX-327 pin 19, NOT pin 2.
