flyingclay
Active Member
I bought a used set of avionics and I am in the process of wiring them up. My pin out wiring from my trans cal encoder ssd 120 has been spliced so most of the pin outs have two wires. Is there a reason for this or should I just cut the second wire and shrink tube it? What would be the reasoning to have two wires for each pin?
Any help here would be appreciated.
Thanks in advance,
Les
Thanks in advance,
Les
