Question: Will the Garmin GPS 20-A provide a "Compliant" signal to a Trig TT-31 Extended Squitter Transponder?
I have spoken to Garmin twice and they don't seem to know. I just had a vigorous debate with a national avionics supplier as I tried to order the 20A and he believes that the 20A with the TT-31 will NOT be 2020 compliant (knowing that it is installed in an EAB airplane). I believe that the TT-31 speaks the proprietary Garmin RS232 plus language so what am I missing?
Thanks for any understanding you can provide.
I think Garmin (or Trig) has to specifically tell you about the combination -
The FAA recommends a WAAS GPS that is compliant with TSO-C145 or TSO-C146. These units are readily available for general aviation and provide sufficient performance to meet the 14 CFR 91.227 requirements. Avionics vendors offer stand-alone GPS receivers and package them with ADS-B transmitters or with GPS Navigators. Mixing and matching GPS systems with ADS-B transmitters in the field is not permitted unless the equipment pairing was shown to be compatible via a previous certification effort with the FAA (for example, an STC). Be sure to contact your manufacturer if you are unsure which GPS systems are approved for your ADS-B transmitter.
- from here -
https://www.faa.gov/nextgen/equipadsb/installing/
Thanks Fred, I guess that makes sense. I am having trouble with Garmin's statement that their GPS 20A..."Meets WAAS/SBAS position source requirements for ADS-B ?Out? and is Compatible with a wide range of 1090 ES transponders." What 1099 ES transponders are they possibly referring to besides their own?
Again, I am not looking for a "certified" combination, only a 2020 compliant combination.
I think to cover all bases you need Garmin to say, "The ADSB+ output from this (GPS-20A) device is exactly the same as that from a Garmin 430W".
The 430W is on Trig's compatible list.
Hello Bruce,
Any 1090ES transponder that is currently compatible with the ADS-B+ RS-232 Output of a GTN 6XX/7XX or GNS 4XXW/5XXW will also be compatible with the same output from a GPS 20A.
The GPS 20A also meets all of the applicable TSO performance requirements for a 14 CFR 91.227 compliant position source (again, same as the certified GTN).
This FAA guidance for homebuilts is probably most useful. It provides this guidance:
For uncertified equipment, the owner should obtain a statement of compliance from the supplier, along with installation instructions, that identifies that the ADS-B equipment complies with section 3 requirements of the applicable TSO and that, when installed in accordance with the installation instructions, complies with the aircraft requirements of 14 CFR 91.227.
If a transponder manufacturer is presently able to provide a statement of compliance when connected to a GTN (installed per the GTN installation manual), then it seems reasonable that they may also provide a similar statement of compliance when using a GPS 20A installed per its installation manual.
Garmin has only tested the GPS 20A with Garmin transponders, but we know of no reason why other 1090ES transponders capable of using the ADS-B+ interface cannot achieve similar results.
Steve
Thank you Steve!
I will pursue a statement of compliance from Trig but it is great to hear that the output of the 20-A is identical to your certified GPS units. I appreciate the help
Bruce
My 2020 plan as well.
Please keep us posted. I have a TT-31 installed in my RV4, and plan to use the 20A for the 2020 ADS-B out requirement as well.
Thank you Steve!
Bruce
Any news on this subject. Did anyone got confirmation from Trig if Garmin 20A will interface in a compliant manner?
From Trig T22 installation manual "Garmin ADS-B protocol, including ADS-B plus" are supported protocols and you can select.
The Trig STC specifies GTN6XX and GTN7XX sources as well as GNS 4XX and 5XX sources.
I guess the question is does Garmin 20A sends exactly the same messages as GTN6XX allowing to select these sources in Trig software? Steve, is that certain?
Thank you.
Hello,
Yes, as stated above "Any 1090ES transponder that is currently compatible with the ADS-B+ RS-232 Output of a GTN 6XX/7XX or GNS 4XXW/5XXW will also be compatible with the same output from a GPS 20A. ".
Steve
Hello,
Steve
Steve, could you point me to an install manual for Garmin 20A.
I just checked my Trig transponder's configuration options in the software and the only selection available is Garmin ADSB, which means there is not a different setting for different hardware. This is good as it means the instruments probably use exactly same protocol.
careful - it needs to say ADSB+. ADSB (no +) is an older format that does not have everything needed.
Good point the STC states that Garmin source (GNS 4XX and 5XX) needs to have its RS232 port set to "ADSB out +". This means that Trig expects that "+" protocol.
Once I see the Garmin 20A install manual I will know more. My other option is Trig TN70 but the price is very high in comparison. The Garmin seems like a nice solution, if it is really compliant.
GPS 20A Installation
Hello Jantar,
The GPS 20A installation is covered in sections 14, 20, 23.10, and page 24-18 of the Rev. V G3X Installation Manual.
It doesn't get much simpler than this. Connect one pair of wires (RS-232) between the GPS 20A and your transponder, and add power, ground, and antenna to the GPS 20A. Turn on the power and the GPS 20A gets a fix and starts transmitting ADS-B+ Out. The ADS-B+ serial output is hard-coded to this configuration, so there is nothing to configure.
As shown on page 14-2, when the status LED on the GPS 20A transitions from flashing to a steady green, you know the GPS 20A has a solid WAAS GPS fix and is good to go.
The CAN bus connection is only needed for G3X/G3X Touch installations, and the NMEA Out connection is optional.
Let us know if you have additional questions.
Steve
Another option is the Dynon 2020 GPS source. Dynon says it is compliant when used with Dynon's transponder which is really a Trig remote transponder. And the Dynon 2020 is less expensive than Garmin.
Jim Butcher
Jim Butcher
There is no software option in Trig that you can select for Dynon 2020. It simply can't be used unless Dynon 2020 speaks Trig ADSB protocol.
Trig 2020 GPS
I have spoken to Trig - they told me they are working on "puck type" 2020 position source, but have no time frame for release at this point.
Yes, the Dynon2020 does not speak a language that the Trig understands.
Sent a note to the nice folks at Trig asking if the GPS 20A would be an approved source for my TT-22 .......
Yes, I can confirm that the GPS20A works just fine as a position source for the TT22 (with the latest software), and the combination will meet the 2020 ADS-B requirements. You can tell your friends at VAF, and in the meantime I have asked the team here to update the manuals to add the GPS20A to the list of supported options.
Andy Davis
Trig Avionics Limited
