Weasel
Tried searching for this but did not turn up a defiant answer.
The G3X installation manual shows the wiring to be shielded for the Oil pressure, Oil Temp and Fuel pressure sensors.
The supplied sensors that came with the Lycoming installation kit has plugs with about 12" of leads that are not shielded. Is the shielding required for stable engine monitor readings?
The Dynon Skyview system in our -10 does not have shielded wire on these sensors and reads very stable.
Anyone have experience with Garmin?
