I will be installing two G5 (one as the AI, the other as a DG) units plus a GMU 11 Magnetometer. The GMU 11 will be installed in the wingtip.
The question is with the wiring that runs between the AI and the GMU 11. Can the power and ground connections be contained within the same shielded cable as the two CAN BUS wires?
Or do the power/ ground wires get run separately and the two shielded CAN BUS wires run separately?
