I recently installed a new Garmin G5 purchased at Oshkosh. Install was easy and the unit powers up as advertised. Only problem is that when I set the current barometer setting while on the ground at my home airport, the altimeter reads 30 feet higher than the field elevation published for my home airport. How do I correct the G5 so it reads an accurate altitude when the current barometer is known.
