uk_RV9A
Active Member
Does anyone know how the case comes apart on a Garmin 796? There appear to be no visible screws, so suspect the back has to prise off but do not want to cause any damage and I don't see anything obvious.
The jack for the external antenna has become partly detached and moving loosely, so I am hoping it just needs resoldering, which I can do if I can get to it and there is no other damage. It is causing reception issues and errors in flight.
Any hints appreciated!
Just to close this thread with some useful information in case anyone else is looking in the future. The back does prise off, revealing the screws that need to be removed. There are an additional two hidden screws under the small removable side panels. The case then opens but be careful to disconnect the ribbon cables before opening too far.
I was then able to resolder the antenna connector, although a very fine tip and solder was required.
