PittsCondor
I'm planning on installing a GNC355 and was wondering if I can easily send the flight plane from the 355 to the 796? If not should I upgrade to the newer Garmin Area 760? If I do will the GDL39 work with the new Area?
Aera 796 Flight Plan Sharing
Good Morning,
Your GPSMAP 796 will work just fine for this purpose. Make sure your 796 software is up to date (latest version is 5.60), and you can easily send flight plans back and forth to the GNC 355.
If you do opt for the newer Aera 760, it is backwards compatible with your GDL 39, so that will continue to provide you with your ADS-B In information.
Please let us know if you have any other questions.
Justin
