I am trying to finish up my serial connections and have a few questions
430W install manual page H-17 shows
Assume using Serial #1
327 serial out supplying altitude to 430W serial in. Format is ICARUS ALT (default)
430W serial out to 327 serial in. What information is being sent here? Do I need this?
Skyview install manual rev L, page 12-6
430W serial out to Skyview 429 module. Format is ?Aviation?.
If I do not need the 430W serial out to 327 serial in, I cannot use it for the Skyview 429 module connection for the Skyview, since format is different, correct? The reason I ask this, is I already this wire in the harness.
On the 430W serial X in and out will be the same format, correct?
