bkthomps
Has anyone ever had an issue where the VNAV Messages were set to "On" but were not displaying? Also I am unable to view the "VSR" value which I usually heavily use
I read that you must be on a FPL or a Direct-> Navigation while getting these values, and have a ground speed greater than 35kts- all of those conditions are satisfied
I have run into this as well.
Are you selecting "GPS" on the "CDI" button? My install won't display the VNAV required unless it's in GPS mode.
oh wow, I never even tried that, and no it's pretty much always on VLOC mode.
Good evening everyone,
here are the parameters for using the VNAV function.
VNAV is inhibited in the following conditions:
? Groundspeed is less than 35 knots
? No active flight plan or direct-to destination
? SUSP mode
? Vectors-to-Final mode
? VLOC mode
? After the FAF on an approach
this is identified in the GNS Pilots guide in the Vertical Navigation Page section.
Best Regards,
