I may not be able to start building my RV quite yet, but I CAN start getting my shop ready! I need help figuring out how I should light the place. I have a 3 1/2 car garage (2 car wide with an extra bay+ in back). I plan on putting most of my workshop in that extra space and need to add lights and outlets. There is currently a single bulb in each bay of my "shop", and I'm planning on using that wiring to put in fluorescent fixtures, but I don't know how many I'll need to adequately light the space.
Measurements are in the image. Ceilings are 10' high, there is a 2x5 window on the long wall (above head height), and half of the walls are currently drywalled. I plan on insulating and drywalling or putting white peg board up on the other walls. You'll have to excuse the spills on the garage floor in the picture (shameful, I know) - we bought a foreclosed house and the evidently the past residents didn't care to keep it clean. I have since scrubbed the floors and will be epoxying it next spring.
http://s913.photobucket.com/albums/ac338/bryostdc/?newest=1
So, any ideas of how much light I need? Along the same lines, the garage is currently on a single 15 amp breaker and only has a couple of outlets. At minimum I will add in a couple more 120v outlets on that circuit. I would love to add another breaker or 240v, but the wiring will have to be pulled from the breaker box on the opposite side of the house through a basement with finished walls and ceiling. Not something I'm looking forward to doing if I can get around it. Will I be okay on one circuit, or do most people have multiple circuits to handle the load from tools? If my lights work and my compressor (I'll probably try to buy a 120v) runs, that should be most of the current I draw at one time, right?
Any ideas would be helpful.
Thanks!
Brandon
Thanks!
Brandon
