F fabio Active Member Nov 4, 2022 #1 is it enough 3/8 of gap between the aluminum baffle and the top cowl? in the instruction is write minimum 3/8 and max 1/2 inch
Mel Legacy Member Mentor Nov 4, 2022 #2 fabio said: is it enough 3/8 of gap between the aluminum baffle and the top cowl? in the instruction is write minimum 3/8 and max 1/2 inch Click to expand... 3/8" is pretty close. I certainly wouldn't want any less than that. Lycomings shake pretty good, especially during start up and shutting down.
