Doing my final assembly of my panel. I'm finding the GAD27 wil only provide voltage to my right landing lights (three bulb LED). Its configured for both lights to fire in wigwag below 70kts. When I bypass the GAD27 the left light works. Tested the toggle to the GAD27 and power in on both lighting inputs but only LIGHT 1 works. Priority is to flash when the switch is on. Have tried all three soft states. One intersting observation, when the main is turned on I geta flash from the left LED assembly, otherwise nothing.
Everything else thru the GAD27 works. I have dimmers, flaps programmed for several steps and speed and keep alive works. Firmware is at the latest. Prior version had same results.
Any ideas?
Michael B.
Any ideas?
Michael B.
