Yes it does and yes you will![]()
I have been reading the G5 manual and it seems that you have to choose whether you connect to individual CAN bus components or only to a G3X system. This makes sense I suppose as I can understand why there can only be one master device on the bus.
However, my question is will the G5 be able to communicate directly with the GAD 29 and other CAN bus components if the G3X fails or drops out of service? I would assume Garmin covers that scenario, but it wasn't clear from the manual.
Larry
Yes, if your G3X Touch GDU 4XX displays become unavailable (for example, turned off to load shed in a power emergency),
Thanks for the response and detail. Just want to be sure this functionality exists with 370 units that I will be installing, as well.
Larry
