Aluminum
I'm sure it's in the documentation, but sure not easy to figure out:
If I use the G5 (without G3X) to drive the autopilot servos using input from GTN 625, will it fly a coupled LPV to minimums, or just horizontal steering?
G5 Approach Capability
This combination of equipment would allow you to fly fully coupled LPV approaches with both lateral and vertical guidance. You would need a GMC 507 autopilot controller to make autopilot mode selections, and a GAD 29 would be required to interface the GTN 625 to the G5.
Justin
Thanks for the clarifications!
If I understand the protocols correctly, with this setup the GTN would not be able to "send" frequencies to a GTR 200? Need G3X for that?
