Crafting N112DR
I have the G3X touch PFD and it works great all by it self, I added a MFD and now the PFD is flagged for all parameters. As far as installing a G3X touch MDF not configured the same as the PFD. What steps do I need to do to get the PFD and the MFD to work together correctly. I did try to installing configuration files but I’m met with a blue swirling icon indication its busy. This only happens for about half a second after that it just disappears and sits there. There does not appear to be any confirmation that is loading. Any help I would so much appreciate.
The PFD needs a program jumper to tell what it is, pins 10 to 27 will do it.
What I'm I jumping? I plug it into the Sub D plug that said MFD. Stein built the harness, Not sure what you're saying.
Remove the back shell or use an ohm meter and check that there is a jumper installed from pin 10 to 27 on the PFD plug.
