Sportquattro
Hi everybody,
OK, over the weekend we did the first engine start on my RV9A (O-320) and fortunately it started right up and ran very nicely which was a massive relief.
The only problem we had was the RPM not registering on the G3X Touch display.
So far we have checked the following:-
The Sensor is the T1A9-1 for the Slick Magneto
The Sensor is in the correct port on the magneto
The wire connections appear to be correct
It is configured under RPM1 in the settings
My next plan is to move the sensor from the Left to the Right magneto as other than it being a duff sensor I can't think of anything else to try before replacing the sensor.
If any knowledgeable soul has any top tips as to anything I may have missed or ways to test the installation then I would welcome all suggestions as changing the sensor isn't going to be easy to do due to limited access behind the panel (Slider canopy)
Thanks in advance
Thanks in advance
