supik
is it possible to set a limit to the fuel on board with a max total value to prevent a mistake by entering a fuel on board value which is above the total capacity of your fuel tanks?
From the current G3X installation manual: (rev AQ)
35.4.32.13.2 Fuel Calculator Configuration
The Fuel Flow calibration page is also used to configure the fuel calculator. Refer to the Pilot’s Guide for information on operation of the fuel calculator.
Full Fuel – Sets the Full Fuel quantity for the fuel computer. Set according to the fuel tank capacity (set to zero if not used).
Partial Fuel 1 & 2 – The Partial Fuel values may be used if the fuel tanks have ‘tabs’ or some other method of putting in a known quantity of fuel (other than completely full tanks). If the Partial Fuel function is not applicable or not desired, these settings can be left blank or set to zero.
