Dorfie
I need help to find the page where I can see and set the rate at which the in flight data is logged to the SD card.
Thanks.
Johan
There is a serial output at 115.2 kbaud, with air data, engine and nav in separate data blocks at different rates. You have to provide the data capture hardware and parsing software. I think the outputs are described in the Installation Manual. I’ll double check when I get home.
APPENDIX C RS-232 TEXT OUTPUT FORMAT in the G3X Touch installation manual describes the 115.2 kbaud serial output.
If you go to Savvy Aviation, you can upload your data for free and see everything on graphs. He has a pay service that I will probably get that analyses the data but seeing all your info in easily read charts is nice.
