Good morning aviators!
I'm having a little trouble deciphering Garmin-Speak/Logic in the AoA configuration for my RV-7.
The pertinent speeds from my aircraft are as follows:
Vs (Stall speed - clean): 54 Kias
Vs0 (Stall speed - 45° flaps): 47 Kias
Vs1 (Stall speed - 15° flaps): 52 Kias
Vat / Vref: 61 Kias
From the G3X Installation Manual, Revision AV, page 30-37:
The settings tab in this menu contains 3 options:
1.Enable AOA Above - Airspeed above which AOA information will appear to the pilot.
2.Disable AOA on Ground Below - Airspeed below which AOA information will be removed from display to the pilot.
My inference from #1 is that the AoA will “come alive” at the airspeed specified and stay there until…the tail comes off?? Vne???. #2 is a little more clear; turn off the AoA on the ground at this airspeed…I think.
I suppose the question I should be asking is how these values interact with the Minimum Visible AoA value (recommended 150% of Vs, Vs0), Caution Alert AOA value (110% of Vs, Vs0), and Stall Warning AoA (Vs).
Here’s the challenge: I don’t want to see the AoA on the PFD/MFD when I am flying above a certain airspeed, for arguments sake, let’s say 80 Kias. (150% of Vs). I also don’t want to be bothered by the AoA display or tones once I’m on the ground and rolling out, which in practice is about 50 Kias (which is about Vs0 - Full Flaps).
As currently configured, I get the AoA indication and tones during take off right about when I lift the tail *and* during the landing, flare/round out, touchdown and roll out...
Cheers!
Brian
Vat / Vref: 61 Kias
Cheers!
Brian
