JDA_BTR
Wrapping up the tanks and about to skin the wings on my -8.
Thinking ahead to a G3X installation. Where on the 8 is a good place to put the ADAHRS? On my 14 it is on the back of the 460 on the panel and running the pitot-static-aoa there was good because the G5 takes pitot-static too.
What about all the other boxes....
It's a rough photo, I choose these positions.
If you need more I can add more views
I built an avionics shelf behind the panel, light weight batteries upfront and put most of the remote LRUs back by the bell crank. I have the Showplanes fastback which changes access, but not overall space.
I think I'm correct when I say, the ADHRS fits on the top of the G3X, an integral part of the G3X.
Magnetometer is a different issue, is that what you meant?
The ADAHRS is the GSU25 and it is a separate unit. It can screw to the back of a GDU460 but in the 8 there might be a better place.
The biggest problem with mounting the GSU 25 to the back of the display is maintenance hassle. You are forced to disconnect the pitot/static lines and GSU 25 connectors every time you remove the display. When you own G3X you remove the display a lot because it provides such a huge access door for the instrument panel. Messing with the pitot/static lines also creates more chances of leaks in the system and can trigger more leak checking than you like.
If you install the GSU on a shelf instead the connectors and pitot/static lines hardly ever get tampered with which is a good thing.
There have been some reports of the GSU not passing the vibration test due to instrument panel flexing vs. a fixed shelf mounting.
On my flying 14A I do have the GSU25 on the back of the PFD 460. It passes tests and is very convenient there. I have push-connect air fittings and it isn't hard to move around if I want. But I haven't moved it in a very long time.
I'm not going to put it there on the 8 I think.....
Aaron that's an interesting shelf at the bell crank. Lots of room there and on the shelf you made; impressive really.
Do yourself a favor and DO NOT mount the GSU25 on the display.
Ok, why not? Not arguing, just curious what problems I can expect.
To the OP, I can't speak for the -8, but on my -6A all units are behind the panel except for the pitot/AOA (of course), and the magnetometer which is under the right wing tip. The GPS antenna is in the left wingtip to avoid COMM and engine noise.
Vibration/panel flexing can cause AHRS issues.
Heat and maintenance access are also contributors to problems.
From the install manual:
"Although mounting the GSU 25 to the threaded holes on the back of the GDU 4XX display is not
generally recommended due to instrument panel flexing."
