I have a question about the power input that doesn't seem to be covered in the manual which only states that there are diodes to prevent current from flowing between the two inputs.
If I have 13.5 volts on power 1 and 13.7 volts on power 2, which one will it use?
In other words, what is the failover logic to power 1 and power2? Does it:
If power 1 voltage drops below minimum switch to power 2?
or
Use whichever one has more voltage?
Also, is it possible to define the switch over voltage?
Matt
or
Matt
