I am upgrading from two Non Touch to one 10" Touch unit. I have a GSU73 and a GSU25. I installed a TOGA button in a discrete pin of the GSU73 but it would not work with my 430W. I recently upgraded from the 430W to a 650xi but I forgot to try the TOGA setup. I have also upgraded from a 305 to a 507. Two questions:
1. Will the TOGA work through the GSU73 without additional wiring through the 650xi. If not, will it work through the 507 plug (507 pin out shows TOGA pins. The 507 will be a great deal easier than doing anything to the 650xi)
2. How do you access Smart Glide on the G3X Touch without wiring a separate switch/button to activate it. If it would be easier to activate it with a separate dedicated button switch, how is it wired (through a discrete on the GSU73 or through the 650xi. (Same question as it relates to the 507 as alternative to wiring separate button)
Someone had recently posted a use for the smart glide application to a non pilot passenger (my wife) much like the level button as a safety factor.
