Helping troubleshoot an EIS hiccup with a friend and his g3x. The MAP is pinned at 32.1" ... and we're in Denver. It should read around 25 or so I believe.
I've tried the configuration page, all options output indications 32 or higher. I've inspected the sensor, braided line to the intake manifold, the mag lines, and wiring. All seems in order.
To be clear it constantly indicates 32 and varies only a few tenths, even when running, and is not a fault X.
This is a new build. Before I recommend a new sensor... any advice on possible setup issues?
