I'm in the process of designing gauge/indicator markings for my RV-8A, and have a few questions:
Most temp / pressure sensors have color options: White, cyan, green, yellow, red. What would the colors white and cyan be typically used to indicate?
MAP: I have an O-360 A1A. How should I design the gauge? A steam MAP gauge I've seen is marked from 10-50 inHg, with a green range between 15-28, and a redline at 28.5. I curious if I can compress the gauge range to 10-35, but I'm unclear about the color ranges.
I am totally confused about how to mark the CHT / EGT bar graph AFA ranges and colors go....
Any suggestions?
Any suggestions?
