Brent 801
Member
I'm in phase one testing with my new RV-14A. I have a persistent problem with MAP and Fuel Pressure indications simultaneously becoming erratic after about 30 minutes of flight. MAP begins fluctuating about .5 inch while FP fluctuates about 4 PSI. I've checked all connectors on the Stein built harnesses and they look fine. I've replaced the MAP sensor and tested the FP sensor with regulated air pressure. I've had 2 A&Ps and an avionics tech look over my installation. I'm about to replace the GEA-24.
Has anyone had a similar experience?
Brent
Brent
