Just installed GEA24 in my IO540. The manifold pressure gauge jumps around about 1 inch, sometimes a little more at cruise, so you end up chasing the number.
Is this normal with others on the forum? Is it possible that the sender is defective?
Thank you.
Thank you. I will check this out.
Thanks Larry, do u by any chance have a part number for Carr?You can get the restrictors in various sizes at Mcmaster carr. .020 to .040 seems to be a good range, though I have .004 on my 10 without a meaninfull lag in response time. I have a home made version on the 6 that works well. Take a -3 Alum line and fill with JB weld, then drill with #60 bit. Then cut line and insert. I use good old vacuum line, but this wont work if you have a braided line.
Larry
One note: Add the removal and cleaning of the orifice to your condition inspection checklist as mine started to clog after 18 or so months and the MP would freeze or move very slowly.
