dbaflyer
I should have noticed this long ago, but now I am getting ready to final rivet the forward fuselage skin and I found this. This is the right side of the panel on the top outer corner of the G3X display.
3THI1n_9Yxpqcx4fLvohnnwheiQ_YPdY_S20fT5nqNvj9CnzWaJBlWCXD2XW49umozIDSLun48LsY1qIjfPJE_mN_ScbVsS2ECq0l87FpjSpKtlNYC6u5vO5_D6mwIF9d5a7VR5OritxV6qpCWwOzwLPT4wWyICEn5g-913PNDVdVf-91AZrb1BEoxPRHLPo7Oxcm6YIzz65N1VDi4iSA6SvgWTNPGevFQgyG_gXd90V8N9_GdiY1gE3b5QbOzjOMXZW1dDYKuSvmNXycbBZF8O0DUS3wmdap1AE-AsKyuGXZYbmwRNB8NsMKicZhvkDLKS2ijn-xFC2ZZCiP5J5E17LrLuCsPre9rOUZ3nA1T4z38SbuNWFoeVKdEb1-ArYJQRWUHlSmHHA_916JK7NAVyZ4GrjXx0l_IMGdaicsxZ3Fe5NM9EK0Wh7PwzYXIMeXjw7JynvmMX4cf8c6Wn2SaS12c6EZID198-rePJVStzHGozpZxLRMC1wtncexYmYR0m-wGhrVULjvNQw1nduuKvAi28kDGRYY2s51XzmLGLtzS0hS4TFNadK1Hcsd6C9gnghSukI4C1SO2Qu5Ucjn8Gi6V39wgt12ogbwCE=w576-h768-no
Options:
1) cut off and do not put a screw here
2) cut it off, rivet another angle outboard of this corner, drill a new hole into the panel for the screw. Fill the existing hole with a screw that does nothing or just leave an empty hole there.
3) Other ideas??
