Wingit
Active Member
Is the information needed, such as oil temp, oil pressure, fuel pressure, v speeds ect. conveniently listed somewhere that could be used to configure G3x system for RV 14 with YIO-390- exp. Thanks
Dave
This does raise a question. How have the rest of you been setting your yellow arcs? For example, on oil temperature how close to the redline do you want the gauge to show yellow?
