backcountry
I'm setting up my initial G3X. Many of the configuration setting are covered in the Vans update file.
The following items need data to be inputted:
Fuel tank calibration
Fuel flow K factor
Elevator Trim indicator conf. settings
Angle of Attack (AOA) conf. settings
If you have this information that would be great
Each aircraft is different
The parameters you listed would be different per aircraft. While it may be helpful to compare values against another aircraft to see how similar they are, it is important that you calibrate each of these values specifically to your aircraft.
The procedure for each of these calibrations is in the installation manual. Installation manual can be downloaded from here: https://support.garmin.com/support/manuals/manuals.htm?partNo=010-00G3X-00&language=en&country=US
-Levi
I agree with you as I'm looking for comparisons.
Vans say they hope to have more on the RV-12, example Fuel flow.
