Flyyak
Friend
I am having trouble calibrating my AOA. I have a GSU73 and GSU25. I have configured the G3X with the AOA to use the GSU25. I have tried to calibrate on several flights and the system accepts the minimun visible and the caution alert. When performing the stall warning it appears to accept it after the power off stall but then says it does not calibrate. Attached are screen shots. Any help will be appreciated.
  • G3X screenshot 03-20-22.pdf
  • G3X screenshot AOA 03-20-22.pdf
  • G3X screenshot AOA config 03-20-22.pdf
This is a kind of non-reply, but...
I got mine calibrated at the power off stall, no problem.
I then looked at the AOA at the other suggested calibration points, and it was close enough, so I didn't bother.
Then again, at my airport I'm always flying non-standard patterns to fit in with airliners and trainers, so AOA isn't very helpful... not to mention how much it jumps around in turbulence.
