Trevor778
Im at that point where I need to start thinking about the FWF kit for my 0-360. Canopy is nearing completion and the engine will be next on the list. Anyone have thoughts on the Vans kit? Those who have bought it would you recommend it?
Absolutely, contains everything you need with instructions.
Excellent! I just purchased mine on Monday ;-)
From reading the forum here, and the general wisdom contained herein, it does seem like a good way forward if you're doing a typical configuration, which I am: IO-360, CS prop. Right up the middle of Van's fairway. It will be helpful to have someone(s) who have thought through the routing of all the cables and electronics carefully, to minimize any potentially very expensive "oops" moments.
I liked the FWF kit from Vans. If you bought the engine and prop from them, Everything is perfect and you don't need to go on a scavenger hunt or gues at what to get. All quality items that fit. I used a quadrant style controller and they were able to substitute the cables for me.
Roberta:)
