Mikeandmaz
Active Member
Hey Guys,
I’m trying to install the Fwd Elevator pushrod CS00001, on to the C00006 control column, but the gap between the fitting is too small for the bearing of the pushrod.
Did anyone else have this problem and if so how did you open up the gap? I’m at a loss to how I can get anything down there to increase the gap, or would filing down the width of the pushrod fitting Be an option?
Mike
Mike - I don't recall any issues with spacing. Is there any possibility that the wrong rod bearing is on the pushrod. I recall a few different sizes/ thicknesses.
If it’s only slightly oversized, then pry the powder coated portion open just a bit with a screwdriver. I’ve found that powder coating thickness can vary slightly. If it’s way off, double check part numbers for the rod end bearing are correct. They’re usually printed directly on the bearing. Otherwise, give the mother ship a call in the AM to troubleshoot. Good luck.
