jmjula
So I am having a lot of the same issues that I see that other builders have had, but I wanted to run by a possible improvement for the way mine is turning out. I have riveted the forward frame hinges and center splice plate already, and it would seem that a hard to avoid error was introduced during that phase. The result is that the left and right sides of the skin are riding up 1/32-1/16" like has happened to many others. If I force the frame to sit lower so that those gaps are non-existent, the center of the frame pulls the skin down ~1/16". So my dilema is where to balance between these two extremes. Here is a picture with the frame pushed low enough to make the sides look good:
Now that I am ready to drill the actual hinge points, I think the best solution is to drill them with things pulled tight, and then add a 1/16" space between the skin and frame once I'm done to fix that. Does this sound like a good enough plan?
![f_canopy_hinge_drill_a.jpg](/community/proxy.php?image=http%3A%2F%2Fjmjula.home.comcast.net%2F%7Ejmjula%2Fimages%2Fcanopy%2Ff_canopy_hinge_drill_a.jpg&hash=c9c9f6f5031376830fe2eca8a89f1b35)
