Aussieflyer
Active Member
At page 27-04 step 2, the plans call out dimpling the web of the firewall except as shown on figure 2. The battery box holes on F 01401B-R (Top of firewall) in the firewall are not called out as being exempt from dimpling. So we dimpled them. They should not have been dimpled.
Likewise at step 5 it calls for the countersinking of the firewall angle F-01401F-R, there are two holes (top set of 2 of the do not rivet call outs) that are applicable to the battery box. We countersunk those. They should not have been countersunk.
Further at page 27-05, step 2 it calls for machine countersinking of all holes of the F-01401D Firewall Angle that match the firewall sides. 6 of those holes match the battery box. We countersunk those. They should not be countersunk.
At page 28-10 at step 3, you will note that it calls out machine countersinking the battery box holes to fit the firewall. The AN426A rivet heads are to fit flush with the battery box. The firewall and angles should not have been dimpled or countersunk as described in the plans
I suggest you put the battery box on the firewall and mark out the relevant rivet holes that should not be dimpled or countersunk. If you take my advice and do not dimple and countersink at 27-04 & 27-05 as cited above you will find you will have clean and flat firewall surface ready to accept a machine countersunk battery box and everything will be fine, otherwise you will end up as I did (following the plans) a minor stuff up. Vans have suggested I can dimple the battery box instead of countersinking - the battery box is made out of .050 6061-T6 its a bit thick to make a good match up I'm afraid. Hope you don't get caught like I did.
