mill2978
I just got the tanks clecoed together and put them on the wing. The alignment of the Z bracket(T-712) to the tank baffle is off. With the tank on the wing I marked the holes through the tank on the Z bracket and pulled off the tank to look.
The spacing from the hole(future) to the edge of the Z bracket is only .228 from the edge.
I removed the T-702 tank baffle and placed it back on the Z brackets using the markings for alignment. I can see the center line I drew on the rest of the Z brackets. The misalignment is on both wings and only on the Z brackets nearest the wing root.
Is this a problem? Should I order two new T-712's or build on?
Aaron
Roll on. You have plenty of edge clearance to shift them about 1/8'. I moved my inboard brackets so I could fit a socket on the AN-3 bolt head. Checkoway method rocks!!!
Do you have proper edge distance for the fastener going in? If you have proper edge distance I would say press on..
It looks like that's the inboard bracket. I'd replace them, as you're a bit under the 0.250" edge distance recommended. Next time around, move the bolt centerline about 1/16" toward the edge of the bracket. In addition to moving the rivet holes, you'll be better able to get a socket on the bolts.
If you haven't already drilled the other six, move the bolt holes toward the flange from the center by 1/16". This will give you a bit more room for the rivet puller when final installing the brackets.
If you aren't familiar with the "Checkoway" method of fitting the tanks to the wing, do a search here in the forums. You'll be glad you did.;)
Success!
Thanks all for the replies, I am using the "Checkoway" method, I just screwed it up.
I decided that it was worth the time to wait and the 5$ to replace the part. It is holding the fuel tank, touches the spar, and I am sure I would be thinking about it in a few years when this bird goes upside down. 5$ is well worth the piece of mind.
I pulled the bad z bracket off, measured how much I needed to shift the holes, clamped the pieces together and drilled the new bracket.
It fits much better :)
