Hello -
Don't have an exact link, but you can check out my brother's web site at
www.our7a.com - that is his builder's log - I believe he had a very good description (including equations for temperature change) showing how to pressure-test with air and a 'U'-shaped tube with water in the bottom of the 'U'. The difference in water height is a precise measurement of the tank's pressure. You can account (compensate for) for differences in height from one day to another by monitoring the temperature each time you take a reading and then using the 'delta T' to subtract-out any temperature induced error - a VERY effective method if done properly. Used the same technique to test my tanks and found a SMALL leak - fortunately was able to fix without opening the tank, since it was near one of the fuel fittings on the 'root rib' (easy fix by reaching in the cover plate).
