AntiGravity
Just looking at this issue now. I had my tanks built for me by Evans Aviation and so far they have not had any fuel on them. I've removed the cover plate and the flop tube and will go about safety wiring as per Vans instructions. Will also proseal those suckers - they're never coming off again; if the safety wire and the proseal fails, then I'll just buy new tubes!!
Question though: should I re-use the cork gasket as is? It's in good nick and wasn't prosealed already (though the screws were). Or should I also use proseal (both sides of the gasket, or just one side and which one?). Or ditch the gasket and use proseal only? I'm thinking if I go gasket only I can always remove and add proseal later...
