dbaflyer
I am starting to leak test the left tank and I'm apprehensive about putting too much air into the tank. I don't want to split it open after all that hard work. It seems like I can pump and pump my bicycle pump and the balloon size does not change. I don't believe there is a major leak anywhere as the balloon size you see is not changing. Am I just to cautious about too much air? And am I more likely to detect a leak if the air pressure inside is enough to force the air out through small holes/gaps?
![LeftTankLeakTest4.jpg](/community/proxy.php?image=https%3A%2F%2Flh6.googleusercontent.com%2F-7tAgLkVDMuY%2FTtUotiHuF6I%2FAAAAAAAAAHY%2Fy_dR9cjnVRI%2Fs640%2FLeftTankLeakTest4.jpg&hash=ad6a2c11b4dd153d30089203b4e14211)
