I put them in. About half way up the rib on the outboard tank rib. I'm not flying yet so I don't know but I'm guessing that the tab will indicate somewhere between 2/3 and 3/4 full. I took great care to be sure that tabs in both tanks were at the same height so that they will indiacte. The nice thing about tabs is that they're fixed, whatever they indicate will never change.
Bevan RV7A wiring
I made a tab like Fred Bauer (post #7 link) and it works great. I actually drilled tiny holes (#55 or something like that) in the tab at every gallon (above about 6, which is what is downhill of the dihedral) with two holes for even gallons and one hole for odd gallons. When I remove my cap, the holes are small enough that they hold fuel and it is easy to see/read the fuel level that way. I also used a scriber to put gallon numbers on the Al tab (made of 032, by the way). Never gets lost or misplaced.
greg
I marked the inside of my tanks with a 1/8 x 1in line every inch from the bottoming on the outside tank rib with pro seal. Will calibrate when I fill tanks.
[/IMG]
William Bennett
CW4 RET USA
RV8A flying
RV7 finishing
I took a lowes paint stick when the tank was empty and made marks every gal works very well.
Bob
