papamike Well Known Member Jan 18, 2011 #1 I intend to install a flop tube in the right tank, and I have float senders. The tube will hit the sender switch. Do I need to relocate something, and if so, where? Thanks
B bkthomps Well Known Member Jan 18, 2011 #2 most people locate it to the spar side of the tank, in the next baffle outboard
papamike Well Known Member Jan 18, 2011 #3 Thanks OK. I've found a few sites from people that have done that.
