pilot28906
How much proseal did you use on the fuel tank baffel? I am trying to decide if I need to order another can. I have both baffels to do and think that it takes quite a bit.
Thanks for the replies; I will probably need to uy another can.
I have a few more questions on the baffel:
1) Why is the baffel flange not "buttered up" with proseal as each rib? It seems that this would provide a better seal?
2) Is the shop heads on the rivets supposed to get covered in proseal?
3) Should there be a fillet around the baffel flange like the ribs?
Sorry for all the questions, I just want to make sure I get this right.
