One other item to check. We had an fuel smell. Turned out a cable's retainer had slipped where the cable was passing by the gascolator. It caught, by the tiniest margin, the little T lever on the bottom of the gascolator, and popped the petcock open. She spit fuel for a bit and we smelled fuel, shut down and did a search. Nothing. Got someone to stand outside while starting and walla, visual on the "leak". Re-did the routing in a way that the line could no longer catch the T lever no matter how hard it tried. This was a pure case of vibration relocating your intended cable route after about 150 hours of no issues. Probably not your issue but figured I'd toss it out there as we were was stumped until someone stood outside during engine start.
