The fuel servo isn?t attached to my newly arrived IO-390. I talked to Lycoming and they said to attach with a nuts, lock washers, and flat washers and use a standard torque. Then when I attached the snorkel it had four bolts that needed to be wired. Seems like if the snorkel is wired, the servo should also. Any thoughts?
