I checked my Vans stock float fuel senders mfg by Warner Stewart prior to closing in the tanks. Ohm readings were in line, float swung unobstructed and freely when installed. 3 years later after putting in fuel in tank both left and right senders don't read off empty. Plenty of fuel in the tanks and jiggled the wings. No change. Then checked the ohm readings between the sender terminal screw and the base with engine monitor gage wire off terminal screw. Reading between the sender screw and the sender base still reading empty (245 ohms).
Pulled the senders. Checked ohm readings-arm up-full and arm down-empty, float arm action, float buoyancy, bends in arm, ease of arm swivel. All checks out on both senders. Reinstalled. Put fuel in tank and still no reading off empty. The left sender has been off 2 times and checked.
Don't know what else there is to check. Don't think this is a ground issue because I'm checking between the sender base and the sender terminal with no wire connected to the terminal.
Brain stormers out there?
Jim
RV9A
Stewart Warner Model 385B-F and 385C-F lever fuel senders
Jim
RV9A
