wirejock
Has anyone used AN hardware for the fuel pump overflow?
Vans suplies a 1/8" pipe to brass tube fitting and plastic tube. Lots of RVs flying with the Vans solution and I know there's no fuel there unless the diaphram fails.
I would like to use AN harware.
I would like to use a 822-4D fitting to aluminum tube.
90 degree 1/8" pipe to flare.
Is the aluminum aluminum fitting ok?
