My IO390EXP119 has a T-fitting on the port side of the fuel pump which allows two hoses to connect: the outlet to the transducer and the restrictor to the fuel pressure sensor. The T-fitting has an O-ring, washer and nut to seal the fitting against the fuel pump. Question is:
What torque to apply on the nut to 'squash' the o-ring against the pump?
Scott
Scott
