kbalch
I got my engine hung last night (I'd forgotten how big a PITA it is to get those cotter pins in!), but ran into a couple of issues today while working on the fuel pump fittings. Two questions:
- Should the inlet fitting (called out as KB-000 on 43-06 fig. 10) come with the FWF kit? It's not on my inventory sheet or, indeed, anywhere to be found.
- Should the brass ferrule F 69-F-04X02 come with a brass insert, as well as a sleeve & nut? If so, mine is missing the insert.
