Atanyspeed
Active Member
Just wondering what other IO-390 builds are getting for fuel pressure in cruise. I’m seeing 18-19 psi. An other aircraft with a 390 was showing 29-30 psi non thunderbolt Engine is running fine with good fuel flow. The engine manuals I’ve read are not clear on the psi coming out of the fuel pump as is set up by Van’s.
